[GRASS-dev] [GRASS GIS] #3057: Problems with Numpy and matplotlib after updating through OSGeo4W
trac at osgeo.org
Fri Jul 8 01:52:28 PDT 2016
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.2.0
Component: Python | Version: unspecified
Resolution: | Keywords:
CPU: Unspecified | Platform: MSWindows 7
Comment (by hellik):
Replying to [comment:1 hellik]:
> Replying to [ticket:3057 veroandreo]:
> > Has anybody had a similar issue? Do I have to manually select or
install some other lib/dependency??
> still an issue, see:
> https://lists.osgeo.org/pipermail/grass-dev/2016-July/081115.html
__________ ___ __________ _______________
/ ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
/ / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
/ /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
\____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS GIS 7.3.svn (r68875)
GRASS GIS homepage: http://grass.osgeo.org
This version running through: Command Shell
(C:\Windows\system32\cmd.exe)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
See citation options with: g.version -x
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Launching <wxpython> GUI in the background, please wait...
Microsoft Windows [Version 10.0.10586]
(c) 2015 Microsoft Corporation. Alle Rechte vorbehalten.
C:\>Numeric,numarray or NumPy not found.
This module requires the Numeric/numarray or NumPy module,
which could not be imported. It probably is not installed
(it's not part of the standard Python distribution). See the
Numeric Python site (http://numpy.scipy.org) for information
on
downloading source or binaries.
on
on
on
tested with
System Info
GRASS Version: 7.3.svn
GRASS SVN revision: r68875
Build date: 2016-07-07
Build platform: x86_64-w64-mingw32
GDAL: 2.0.2
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3057#comment:4>
