[GRASS-dev] [GRASS GIS] #3093: v.in.ogr: shapefile with Date/NULL-field prevents creation of db-table
trac at osgeo.org
Fri Jul 8 13:36:32 PDT 2016
Reporter: Melwin | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Vector | Version: 7.0.3
Resolution: | Keywords: v.in.ogr, sql,
CPU: Unspecified | Platform: MSWindows 7
Changes (by martinl):
* keywords: => v.in.ogr, sql,
* component: Database => Vector
Comment:
Date is reserved SQL word. It cannot be used for column name. You can
rename this column using `columns` options (whole list of columns must be
defined). The module could be of course more cleaver and rename such
column automatically eg. to `Date_`.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3093#comment:1>
