[GRASS-dev] [GRASS GIS] #3084: i.segment: allow more than	2147483647 cells
    trac at osgeo.org
    Mon Jul 11 12:36:16 PDT 2016
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.2.0
 Component:  Imagery      |    Version:  unspecified
Resolution:               |   Keywords:  i.segment variable type
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:2 mlennert]:
 > Replying to [comment:1 mmetz]:
 > > Replying to [ticket:3084 mlennert]:
 > > > In iseg.h, notnullcells is defined as long. On Windows this has a
 range of –2147483648 through 2147483647.
 > > > We are working on a region that has over 7 billion pixels and so the
 nonnullcells variable overflows, becomes negative and i.segment fails with
 "insufficient number of non-null cells".
 > > > Two reflections:
 > > > * Shouldn't this be unsigned ?
 > > > * Maybe a long long would be safer, seeing that pixel numbers don't
 stop increasing.
 > > For nonnullcells, long long would be ok. But i.segment is not prepared
 to handle raster maps with more than 2147483647 cells, at least the region
 IDs would also need to be changed, or handled differently. Variables for
 region ID as well as the region ID output is 32 bit signed integer, so
 there will be another integer overflow, particularly because in the
 beginning each cell gets a unique region ID.
 > Ok, so I'll retype the ticket to enhancement request and change the
 title to reflect the demand for i.segment to handle over 2147483647 cells.
 Other than changing variable types, does this entail any other changes ?
 Most importantly, a GRASS raster format for 64-bit signed integer. Note
 that GDAL does not support 64-bit signed or unsigned integers. The reason
 is probably that a portable implementation of 64-bit integers is not so
 easy. Regarding GRASS raster processing, the need for 64-bit integers
 usually arises only for raster maps with more than 2,147,483,647 cells
 which in turn usually requires Large File Support (LFS). Therefore the
 check for the availability of a 64-bit integer could be coupled to LFS. If
 support for 64-bit signed integer raster maps (say, LCELL) could be added
 to GRASS, users would need to stick to GRASS since GDAL raster export of
 64-bit integers is not available. Interesting idea. In r68944, I have
 implemented for i.segment conditional support for 64-bit signed integers:
 long long int or a 64-bit off_t or a 64-bit long int must be available.
 r68944 does not solve but alleviates the problem if the current region
 comprises more than 2,147,483,647 cells. r68944 also adds checks for
 integer overflow. The handling of initial region IDs has been changed and
 the module is now about 6x faster for regions > 10 million cells,
 depending on the threshold value for region growing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3084#comment:3>
