[GRASS-dev] question on workspace file - wxGui
Anna Petrášová kratochanna at gmail.com
Mon Jul 11 13:40:20 PDT 2016
On Mon, Jul 11, 2016 at 9:35 AM, Robert Kuszinger <kuszinger at giscom.hu> wrote:
> Hello!
> I'd like to get information in python script whether:
> if wxGUI running or not, and if yes:
the only thing related to that was implemented for g.gui.* modules:
https://trac.osgeo.org/grass/changeset/67232
which passes grass interface object to the main function of the
script. But this needs to be run from the GUI.
> the name of the current workspace file, if set (opened or saved) or clearly
> a "no" answer if not
there is information if workspace is loaded and if it has been changed
since, but it's not easily accessible, that would have to be part of
the interface. May I ask you what's your use case?
> A multi-OS solution is welcome (linux ps filtering for wxgui works but I
> need something cross-platform, GRASS internal if possible)
> I tried to look in sources but spent to much time and I have no idea still.
> Any help is welcome.
> Best regards and thanks
> Robert
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
