[GRASS-dev] [GRASS GIS] #3044: d.northarrow: transparent color does not work
trac at osgeo.org
Tue Jul 12 05:50:46 PDT 2016
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Default | Version: unspecified
Resolution: | Keywords: d.northarrow, cartography, gsoc2016
CPU: | Platform: All
Unspecified |
Comment (by lazaa):
Replying to [comment:1 wenzeslaus]:
> When the fill color is set to transparent (`fill_color=none`) in the
G7:d.northarrow, it is rendered as `black`.
> d.northarrow style=arrow1 at=85.0,25.0 color=30:144:255 fill_color=none
> Support for transparency, would increase the number of style options. I
can see how even transparent line color would potentially create some
interesting options as well.
> Other modules support that but if it is too difficult to implement, the
transparent option should be removed.
It looks that D_parse_color() returns same value both for input string
"black" and "none". Could you provide me an example of module where
transparency is already implemented?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3044#comment:2>
