[GRASS-dev] [GRASS GIS] #3100: v.vol.rst WARNING in GRASS 7 still says cellout and cellinp rasters
trac at osgeo.org
Wed Jul 13 03:01:57 PDT 2016
Reporter: rorschach | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Default | Version: 7.0.4
Keywords: | CPU: x86-64
Platform: Linux |
A very minor issue. GRASS 7 changed the names of cellinp and cellout
parameters of the v.vol.rst module to cross_input and cross_output
respectively but when the module issues a warning it still says:
WARNING: Unable to create '''cellout''' raster map without '''cellinp'''
(''emphasis supplied'')
This may be minor but I think it throws off a user because there is no
cellout or cellinp option anymore in GRASS 7.
I haven't checked if the same goes for other WARNING/ERROR messages for
other modules. The main source code probably needs a little proofreading
to avoid simple ''defects'' like this. I would volunteer but I don't have
access to the main svn (yet).
Thank you.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3100>
