[GRASS-dev] [GRASS GIS] #3105: r.stats.zonal parameter description
trac at osgeo.org
Fri Jul 22 13:46:32 PDT 2016
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
In the manual page of r.stats.zonal, one has to give a base raster map and
a cover raster map. From these terms alone it may not be clear which map
should be what without going to the (linked) r.statistics manual page. I
would like to suggest to:
1) copy the relevant parts to the description on the r.stats.zonal manual
page.
2) describe the parameter base as "Name of base/zonal/category raster
map". At minimum, use the word 'zonal' (it is part of the name of the
function for a reason)
Point 2 applies to the description of the 'base' parameter of r.statistics
as well.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3105>
