[GRASS-dev] some detail questions on i.segment
Moritz Lennert
mlennert at club.worldonline.be
Wed Jun 1 05:24:41 PDT 2016
Another question concernant i.segment's details:
IIUC, the threshold used in region-growing is normalized using a common
denominator defined by:
divisor = globals->nrows + globals->ncols;
(BTW, why '+', not '*' ?)
Row and column numbers come from
globals->nrows = Rast_window_rows();
globals->ncols = Rast_window_cols();
The threshold is then adjusted to take into account object size, i.e. to
favor merging of smaller regions compared to merging of larger regions:
adjthresh = pow(alpha2, 1. + (double) smaller / divisor);
It is this adjusted threshold that is used to decide whether to merge
regions or not, depending on whether their similarity is smaller than
this adjusted threshold or not.:
if (compare_double(Ri_similarity, adjthresh) == -1)
Ri_similarity is normalized by
val /= globals->max_diff;
where globals->max_diff is defined as the difference between max anf min
values in the input file, as obtained by
Rast_get_fp_range_min_max(&(fp_range[n]), &min[n], &max[n]);
I hope that I've understood all of this correctly.
Now my question:
Are nrows and ncols region-dependent, i.e. will the divisor in the
calculation of the adjusted vary depending on the region I defined ?
And max->diff do I understand correctly that Rast_get_fp_range_min_max()
is region-independent, i.e. that if I take different regions of the same
image, I will always get the same max_diff ?
If this is correct, does this mean the region size might determine
whether some objects (or pixels) are merged or not ?
This would put into question the determination of a good threshold by
testing on small regions as the same threshold might not have the same
effect in larger regions, or ?
Moritz
On 20/05/16 18:40, Markus Metz wrote:
> Hi Moritz,
> On Wed, May 18, 2016 at 6:36 PM, Moritz Lennert
> <mlennert at club.worldonline.be> wrote:
>> Hi Markus,
>> I'm working on potentially improbing the i.segment.uspo addon and am looking
>> at the possibility of including the goodness of fit output map somehow in
>> the evaluation of the quality of the segmentation.
>> For that, I need to exactly understand the goodness of fit measure.
>> As a starter: why is the threshold parameter (globals->alpha) squared before
>> being used in create_isegs.c (and in the calculation of the goodness of fit)
>> ? Is it because i.segment works with the squared distance and not the actual
>> distance ?
> Yes, i.segment works with the squared distance to avoid sqrt() which
> is slow. All that matters is if the distance is larger or smaller than
> threshold, and this relation is the same with squared values.
>> IIUC, the worst goodness of fit measure (i.e. 1 - difference) is equal to
>> the 1 - threshold parameter value. This thus means that if one would want to
>> compare segmentations done with different threshold values by comparing mean
>> goodness of fit, for example, this would have to be scaled taking into
>> account the respective parameter value. Would something like
>> ( goodness of fit - (1 - threshold parameter value) ) / threshold parameter
>> value
>> make sense ?
> The goodness of fit is currently 1 - similarity by comparing the
> current cell values to the object's mean values. Similarity is in the
> range [0, 1], 0 means identical, 1 means maximum possible difference.
> With the region growing algorithm, that difference can actually be
> larger than the given threshold if a cell is included in an object and
> subsequent growing of the object shifts the mean away.
>> BTW, in write_output.c, in the comments starting at line 82, there is
>> mention of a globals->threshold, but there is not threshold in the globals
>> structure... I guess this should read globals->alpha or threshold->answer,
>> or ?
> The comments starting at line 82 in write_output.c are an idea for
> goodness of fit, the actual goodness of fit is calculated in lines 168
> and 182.
> HTH,
> Markus
Département Géosciences, Environnement et Société
Université Libre de Bruxelles
Bureau: S.DB.6.138
CP 130/03
Av. F.D. Roosevelt 50
1050 Bruxelles
Belgique
tél. + 32 2 650.68.12 / 68.11 (secr.)
fax + 32 2 650.68.30
