[GRASS-dev] [GRASS GIS] #3038: Decide if validity check in r.in.lidar should be an additional filter or a filter enabled by default
trac at osgeo.org
Wed Jun 1 06:13:23 PDT 2016
Reporter: wenzeslaus | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 7.2.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.in.lidar, r3.in.lidar,
CPU: | v.in.lidar, libLAS, PDAL
Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:2 wenzeslaus]:
> Replying to [comment:1 mlennert]:
> > ...the general rule of no API changes within the same major number
releases...
> It is changing behavior because the output might be different. However,
it does not break scripts in general, although you might just get more
points or invalid points depending on your data.
IMHO, the output counts as well, not only the fact that scripts might
break.
But as you say, in light of the very unclear definition of these points,
one could consider the silent suppression of points a bug, and so your
flag proposal a bug fix.
So, I would say: go ahead with your proposal (flag to filter non-valid
points), but maybe the module should output an information message about
this change.
> > * In the long run: determine whether libLAS is still a good choice...
> Right. I think PDAL (which BTW doesn't have any validity check) is a
good replacement, but I wasn't able to touch it for some time (#2732).
Yes, I guess PDAL would be a better choice than LASlib... It would be
great if there were a C-API to PDAL. I would be a bit hesitant to
introduce C++ dependence in what would probably be considered a core
module.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3038#comment:3>
