[GRASS-dev] [GRASS GIS] #3041: Grass Nviz crashes
trac at osgeo.org
Wed Jun 1 20:40:28 PDT 2016
Reporter: virtuale71 | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.5
Component: wxGUI | Version: 7.0.4
Resolution: duplicate | Keywords: m.nviz.image
CPU: x86-64 | Platform: MSWindows 7
Comment (by wenzeslaus):
Replying to [comment:3 virtuale71]:
> Can this depend upon my system? I have a PC, does somebody knows if
there is the same problem on Mac?
m.nviz.image works well on Linux and Mac (except for an error at the end
of rendering on Mac where it reports some error but renders the image).
wxGUI 3D view should give high resolution image when your screen is high
resolution regardless of platform (you still need enough memory for the
data, 64bit version is helpful in this (64bit GRASS GIS is standard on
Linux and it is new on MS Windows, but note that MS Windows depending on
the version artificially limit memory usage in different ways)).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3041#comment:4>
