[GRASS-dev] [GRASS-SVN] r68555 - grass/trunk/imagery/i.segment
Markus Metz
markus.metz.giswork at gmail.com
Fri Jun 3 01:06:40 PDT 2016
On Wed, Jun 1, 2016 at 7:31 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Jun 1, 2016 at 10:41 AM, <svn_grass at osgeo.org> wrote:
>> Author: mmetz
>> Date: 2016-06-01 01:41:21 -0700 (Wed, 01 Jun 2016)
>> New Revision: 68555
>> Modified:
>> grass/trunk/imagery/i.segment/create_isegs.c
>> Log:
>> i.segment: fix manhattan distance
>> Modified: grass/trunk/imagery/i.segment/create_isegs.c
>> --- grass/trunk/imagery/i.segment/create_isegs.c 2016-06-01 08:39:29 UTC (rev 68554)
>> +++ grass/trunk/imagery/i.segment/create_isegs.c 2016-06-01 08:41:21 UTC (rev 68555)
>> @@ -176,7 +176,7 @@
>> /* squared manhattan distance, sum the differences for each dimension */
>> do {
>> - val += Ri->mean[n] - Rk->mean[n];
>> + val += fabs(Ri->mean[n] - Rk->mean[n]);
>> } while (n--);
>> /* the return value should always be in the range 0 - 1 */
> I see this bug also in the other branches, shall I backport it?
Yes, thanks!
Markus M
> markusN
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
