[GRASS-dev] [GRASS GIS] #3055: Revise monochromatic color tables
trac at osgeo.org
Sat Jun 4 20:09:56 PDT 2016
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Display | Version: unspecified
Keywords: r.colors, d.rast, blues, greens, | CPU: Unspecified
oranges, reds, sepia, water |
Platform: Unspecified |
The monochromatic color tables namely `blues`, `greens`, `oranges` and
`reds` added in r64283 start with white. It is probably obvious that it is
good that there is no black but I think that they also should not contain
white.
Using r.mapcalc, r.colors, and r.colors.matplotlib (`g.extension
r.colors.matplotlib`), you can try how the Matplotlib `Blues`, `Greens`,
`Oranges` and `Reds` look like.
color=blues
map=m_$color
g.region cols=500 rows=300 n=-300 s=-600 w=0 e=500
r.mapcalc "$map = col() / 10 + 2 * cos(col() * 100)"
r.colors map=$map color=$color
color=Blues
map=m2_$color
g.region cols=500 rows=300 n=-600 s=-900 w=0 e=500
r.colors.matplotlib map=$map color=$color
Also Moritz mentioned off-list that ''a quick look at Color Brewer shows
that they use values such as:''
255:255:229 for greens
255:247:236 for reds
You can notice that besides different start color Matplotlib uses also
different end color. Our color versions end e.g. with 0:0:255 (called
`blue` in GRASS) which is an arbitrary color based on its special position
in the RGB model not on its optical or aesthetic features. For the
technical part, the `greens` and `blues` does not show the waves on the
right and in comparison with the Matplotlib versions it seems to me that
even `reds` and `oranges` show less waves on the right.
I'm not sure how many color steps are needed for the Matplotlib colors. I
used 6 but perhaps just 2 (start and end) are enough.
The `sepia` color table from r33163 actually starts with white, `0:0:0`,
and ends with (almost) black, `255:254:251`, (or the other way around when
you don't use `-n`), so that's not good I think. I'm usually not able to
use it because of the black color. The gray scale image and the waves are
good (these two look like good indicators, see #3043). So, I would just
remove the stretch the current colors unless there is some good sepia
color table source.
The `sepia` color table from r68464 (from r.lake) doesn't show a big
gradient in gray scale (which might be good thing sometimes, but not now).
However, there is some and I don't know how to change it while preserving
other features especially the look which I think is really good here.
Note that changing these would be more serious change in behavior because
your result is changed even if you explicitly specify what you want (which
is not the case for change of default in #3043 where you just trust the
default which is changed for your good).
Note also that a monochromatic color tables are candidacies for new
default color table (#3043).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3055>
