[GRASS-dev] [GRASS GIS] #3056: ]PATCH] r.patch: disable creation of support files
trac at osgeo.org
Wed Jun 8 23:52:17 PDT 2016
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.2.0
Component: Raster | Version: unspecified
Resolution: | Keywords: r.patch categories colors
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:2 neteler]:
> A wish - the current manual change proposal (maybe remove "very"):
> "This can be quite time consuming for certain maps, especially if there
are ~~very~~ many different category values across the patched maps. The
<em>-s</em> flag allows to disable support file creation."
Done in the new version of the diff.
> should also mention the side effects when using the proposed flag. Will
other modules still accept such maps? Anything specific which will no
longer work and how to work-around?
AFAIK, the only difference is that no category labels or color tables from
the original maps are kept, but this will not cause any issues for other
modules.
I enhanced the explanation in the patch.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3056#comment:3>
