[GRASS-dev] Towards SVN - git integration
Rainer M Krug
Rainer at krugs.de
Thu Jun 9 03:40:41 PDT 2016
Jachym Cepicky <jachym.cepicky at gmail.com> writes:
> Hi,
> (after a while)
> I agree with Rainer - and I understand the conservative point of view
> - and still remember last change from cvs to svn. Meanwhile, couple of
> you might have custom scripts which do enable similar magic in svn,
> which are natural to git (without any need for hacking). Git really
> makes it *very* easy to merge code and solve conflicts, not to mention
> possibility of forking and pulling from various repos (more organised
> way of accepting someone's code).
Just to clearify - forking and pull and push requests are github
features - not git. Nowadays github is so sexy, that its features are
often confused with being git features.
> I think, it's possible to have the main repo in Git and access it with
> svn client, if I'm not mistaken. But moving to git as main repo would
> be wise option IMHO.
> Github certainly is great service. Custom GitLab instance on (OSGeo?)
> server should certainly be considered.
In the long run would a GitLab server possibly be the best option. But
in the meantime a move to github would be the easiest and all features
for which github is famous are there.
> But what is the difference between GitHub and Intevation (for those,
> who remember)? Just the scale business model IMHO, but the principal
> is the same - private companies hosting infrastructure for open source
> projects.
This is exactly why many dislike github. But as you said, gitlab is also
an option which has very nice features (also CI for testing).
Cheers,
Rainer
> Just my 2 cents
> J
> čt 9. 6. 2016 v 11:37 odesílatel Rainer M Krug <Rainer at krugs.de> napsal:
> Markus Neteler <neteler at osgeo.org> writes:
> > Hi devs,
> > at time I am aware of two GRASS GIS related git instances:
> > * https://github.com/GRASS-GIS (used for Travis CI, in sync)
> > * https://git.osgeo.org/gogs/grass/grassgis (slighly outdated)
> > It would be nice to go towards a bidirectional SVN <--> git(hub)
> > integration in order to collect easily contributions.
> > Any suggestions how to proceed?
> I know there are many who prefer svn to git, but the question is if the
> main repo should migrate from svn to git.
> If the decision is to have a git(hub) repo, I would suggest completely
> moving to git.
> I don't think one can reliably and automatically keep two repos in sync.
> As it looks now, grass-ci seems to be updated automatically.
> Cheers,
> Rainer
> > Markus
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
> Rainer M. Krug
> email: Rainer<at>krugs<dot>de
> PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160609/e36391cb/attachment.sig>
