[GRASS-dev] [GRASS-user] GRASS for Mac 64bit, wxPython 3, maybe fix for SIP problem - please test
Michael Barton
Michael.Barton at asu.edu
Thu Jun 9 13:30:22 PDT 2016
yet another GRASS 7.3 64 bit.
In this version (just uploaded a few minutes ago to the website), I've built wxPython from source and installed it in a non-system folder. I built GRASS against this local build of wxPython. There should be no problems for SIP if it is only the bundled dependencies. And this should not require any additional packages like Anaconda.
Let me know
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jun 6, 2016, at 12:37 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
OK. This means the /usr/local/... path is hardwired into the wxPython Mac binary itself. Not sure if this changes how we need to deal with this.
Michael
C. Michael Barton
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
On Jun 6, 2016, at 12:15 PM, Adam Dershowitz <adershowitz at exponent.com<mailto:adershowitz at exponent.com>> wrote:
I just downloaded it, and tried it. No luck. It still doesn’t find the libraries that it needs:
'/Applications/GRASS-7.3.app/Contents/MacOS/grass.sh'; exit
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Python 2.7.10 found.
Cleaning up temporary files...
Starting GRASS GIS...
File "/Applications/GRASS-7.3.app/Contents/MacOS/gui/wxpython/gis_set.py", line 31, in <module>
from core import globalvar
File "/Applications/GRASS-7.3.app/Contents/MacOS/gui/wxpython/core/globalvar.py", line 96, in <module>
import wx
File "/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/__init__.py", line 45, in <module>
from wx._core import *
File "/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_core.py", line 4, in <module>
import _core_
ImportError: dlopen(/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_core_.so, 2): Library not loaded: /usr/local/lib/wxPython-3.0.2.0/lib/libwx_osx_cocoau-3.0.0.2.0.dylib
Referenced from: /Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_core_.so
Reason: image not found
ERROR: Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.
To run GRASS GIS in text mode use the -text flag.
Exiting...
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
Deleting expired sessions...none found.
[Process completed]
-- Adam
From: Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>>
Date: Monday, June 6, 2016 at 2:50 PM
To: Adam Dershowitz <adershowitz at exponent.com<mailto:adershowitz at exponent.com>>
Cc: GRASS developers <grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>>, GRASS users <grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>>, Helena Mitasova <hmitaso at unity.ncsu.edu<mailto:hmitaso at unity.ncsu.edu>>, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>>
Subject: Re: [GRASS-user] GRASS for Mac 64bit, wxPython 3, maybe fix for SIP problem - please test
Adam and others,
Yet another GRASS 64 bit. I just uploaded to the GRASS for Mac site.
I tried something else. I am hoping that this works with SIP enabled in El Capitan and does not add Anaconda as a required dependency.
If you have a chance, give it a try.
Michael
C. Michael Barton
www: http://www.public.asu.edu/~cmbarton<https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=CwMF-g&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=EptVyHvN5Hy-kJAyE5zVpjKVi-Hj12JwOOKM6yUgzF0&s=34kfotLDUf5mRfMlJY9uXiBzLxZFhHfdFsRiE5hwz0s&e=>, http://csdc.asu.edu<https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=CwMF-g&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=EptVyHvN5Hy-kJAyE5zVpjKVi-Hj12JwOOKM6yUgzF0&s=M_LT_GhsO_-fWH5lR5tqThIl7ZwPXZN68wY9zdZVpwM&e=>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160609/093a7f75/attachment-0001.html>
