[GRASS-dev] [GRASS GIS] #3014: Add ticks to continuous raster legend
trac at osgeo.org
Sat Jun 11 14:32:15 PDT 2016
Reporter: annakrat | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.3.0
Component: Display | Version: svn-trunk
Resolution: | Keywords: d.legend, gsoc2016, cartography
CPU: Unspecified | Platform: All
Comment (by lazaa):
I uploaded new patch and I added several new options. Option {{{title}}}
to define custom title to display on the top of the legend.
d.legend raster=srtm title="Map legend"
An option {{{tick_value}}} to specify values where the ticks and labels
will be displayed. Option {{{labelnum}}} is used to show only min and max.
d.legend raster=srtm labelnum=2 tick_value=1000,1848,2700,3500
Then option {{{step}}} to draw ticks and display labels at rounded values-
values divisible by {{{step}}} value with rest 0. (Flag {{{-c}}} is used
to hide labels generated from {{{labelnum}}} and to display only labels
with defined interval.)
d.legend raster=srtm -c step=500
I've tested it for vertical/horizontal and normal/flipped legend it works
fine. There's a problem with horizontal legend if user define more ticks
then longer labels can overlap.
More testing welcome.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3014#comment:3>
