[GRASS-dev] [GRASS GIS] #3062: Segmentation fault with r.buffer
trac at osgeo.org
Wed Jun 15 14:44:50 PDT 2016
Reporter: escheper | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.5
Component: Raster | Version: 7.0.4
Resolution: | Keywords: r.buffer
CPU: Other | Platform: Linux
Comment (by escheper):
Thanks for your support!
Reading the map didn't cause the problem. The method read_input_map()
finishes without a fault.
The segmentation fault occurs in execute_distance() in execute.c after the
message "Finding buffer zones..." is shown.
After adding "G_free(map);" in read_input_map() the r.buffer command
crashes within that method and execute_distances() isn't executed. So I
removed the "G_free(map)" again.
After adding some debug statements I have noticed the program crashes at
the following point in process_left().
/* convert 1,2,3,4 to -1,0,1,2 etc. 0 becomes ndist */
G_message(_("PL6"));
G_message(_("cur_zone: %i ZONE_INCR: %i ndist: %i to_ptr:
%i"),cur_zone,ZONE_INCR,ndist,to_ptr);
if ((cur_zone = *--to_ptr))
cur_zone -= ZONE_INCR;
else
cur_zone = ndist;
The last lines of the debug output was:
PL6
cur_zone: 16538 ZONE_INCR: 2 ndist: 1 to_ptr: -2116621104
Segmentation fault
I do not have much experience with C so maybe you can give me a clue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3062#comment:7>
