[GRASS-dev] [GRASS GIS] #3013: support background and border for d.legend
trac at osgeo.org
Thu Jun 16 05:17:55 PDT 2016
Reporter: annakrat | Owner: grass-dev@…
Type: | Status: new
enhancement |
Priority: normal | Milestone: 7.3.0
Component: Display | Version: svn-trunk
Resolution: | Keywords: d.legend, background, gsoc2016,
CPU: | cartography
Unspecified | Platform: All
Comment (by lazaa):
Replying to [comment:10 annakrat]:
> > > Replying to [comment:7 lazaa]:
> > > > Added flag {{{-b}}} and option {{{brdcolor}}} and {{{bgcolor}}} to
draw background. Also added option{{{font_size}}} as requested. Code was
separeted from main.c to background.c and draw.c. For background purpose
in case of {{{-d}}} flag (histogram) added function calc_histogram in
histrogram2.c
> Tested, it works. However, the code is not maintainable like this, you
have too large overlap between `draw` and `background` functions. I
suggest to merge those functions and use ifs and put some parts into
separate functions. Also check during compilation for warnings, there were
a couple of them, probably not serious, but better to fix them.
That's right, I didn't realize possible problems with maintaining code. So
I moved it to one function and used parameter {{{draw}}} and if
conditions. Draw=0 is for calculation and draw=1 for calculation and
drawing. I don't get any warnings now, so I hope it's OK.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3013#comment:11>
