[GRASS-dev] [GRASS GIS] #3062: Segmentation fault with r.buffer
trac at osgeo.org
Thu Jun 16 21:07:47 PDT 2016
Reporter: escheper | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.5
Component: Raster | Version: 7.0.4
Resolution: | Keywords: r.buffer
CPU: Other | Platform: Linux
Comment (by annakrat):
I would say it is related to the fact that `to_ptr` is unsigned char, so
it can overflow fast, although I don't understand the algorithm there.
Note the comment in the code:
/* if MAPTYPE is changed to unsigned short, MAX_DIST can be set to 2^16-2
* (if short is 2 bytes)
So I would try to change it to unsigned short. Unfortunately I can't
easily test the testcase, I have little memory right now.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3062#comment:10>
