[GRASS-dev] [GRASS GIS] #3013: support background and border for d.legend
trac at osgeo.org
Fri Jun 17 05:51:51 PDT 2016
Reporter: annakrat | Owner: grass-dev@…
Type: | Status: new
enhancement |
Priority: normal | Milestone: 7.3.0
Component: Display | Version: svn-trunk
Resolution: | Keywords: d.legend, background, gsoc2016,
CPU: | cartography
Unspecified | Platform: All
Comment (by lazaa):
Replying to [comment:12 annakrat]:
> Thank you, I committed it in r68699. I did some minor changes in
guisections and fixed one warning (-Wreturn-type). I have two more
suggestions:
> * if you use different font than the default one, the background box is
larger than it should be. You don't use `D_get_text_box` there, I wonder
if this would give you better estimate?
Thank you! Before there was a constant for font height/width ratio, which
works only for romans font. With {{{D_get_text_box}}} it works now for all
fonts much better.
> * The ticks are currently rendered in the same color as text, but they
should be black as the legend outline.
I changed it to black color.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3013#comment:14>
