[GRASS-dev] [GRASS GIS] #3068: Raise a warning/error when where parameter is not correctly set
trac at osgeo.org
Sat Jun 18 12:33:18 PDT 2016
Reporter: veroandreo | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.3.0
Component: Temporal | Version: svn-trunk
Keywords: where | CPU: Unspecified
Platform: Linux |
I have a set of 16 years of MODIS data starting on February 18, 2000. My
intention was to aggregate data seasonally (3 months granularity), but as
start is shifted, I wanted aggregation to start from April 1st. This was
my command:
t.rast.aggregate --o input=${var}_${tile} method=average \
output=${var}_${tile}_seasonal_average \
basename=${var}_${tile}_seasonal_average \
suffix=gran where="start_time >= 2000-04-01 00:00:00" \
granularity="3 months"
I forgot to write 'single quotes' around the date. Therefore, the where
parameter was ignored and all my seasons shifted and I had to
run all over again.
Would that be possible to check if the where clause is "well-written" and
raise an error/warning if it is not??
Thanks so much in advance!
ps: I guess I will double check for single quotes tons of times from now
on
Ticket URL: <https://trac.osgeo.org/grass/ticket/3068>
