[GRASS-dev] map display enhancement
Anna Petrášová kratochanna at gmail.com
Mon Jun 20 07:05:37 PDT 2016
On Mon, Jun 20, 2016 at 6:03 AM, Vincent Bain <bain at toraval.fr> wrote:
> Hi list !
> playing around with multiple layers in the map display I wonder if
> anyone ever suggested to introduce blending modes beside the already
> implemented "opacity" option. I mean it would be great to be able to
there is r.blend as you probably know.
> combine layers with various options (commonly known as Multiply, Screen,
> Addition, etc.).
could you also suggest a use case for these to better understand the
advantages?
> It's probably a big task. Let me know if you think it is worth opening a
> ticket for that.
yes, sure. What I miss is semi-transparent rendering of layers with d
commands, now g.pnmcomp is used in the gui, but it's very inconvenient
for scripting.
Anna
> Yours,
> Vincent.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
