[GRASS-dev] [GRASS GIS] #2683: grass 7 doesn't start in text mode on CentOS 7
GRASS GIS trac at osgeo.org
Mon Jun 20 16:25:04 PDT 2016
  Reporter:  morenocomelli  |      Owner:  grass-dev@…
      Type:  defect         |     Status:  new
  Priority:  normal         |  Milestone:  7.0.5
 Component:  Startup        |    Version:  7.0.0
Resolution:                 |   Keywords:  centos
       CPU:  Unspecified    |   Platform:  Unspecified
Comment (by neteler):
 Replying to [comment:13 rbarnes]:
 > I'm running GRASS on a headless machine, so it wasn't possible for me to
 use a GUI on it.
 Right.
 On headless machines, use
 grass70 /path/to/location/mapset
 and the rc file will be generated.
 > I ended up installing GRASS on a spare machine, installing all the GUI
 packages, using the GUI, and then copying the contents of the resultant RC
 file and the associated directory structure to the headless machine.
 > I have not found instructions for "Create manually GISRC file", but, if
 those existed somewhere and the help text referenced them, that would be
 ideal.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2683#comment:14>
