[GRASS-dev] [GRASS GIS] #2683: grass 7 doesn't start in text mode on CentOS 7
trac at osgeo.org
Tue Jun 21 06:55:00 PDT 2016
Reporter: morenocomelli | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Startup | Version: 7.0.0
Resolution: | Keywords: centos
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:14 neteler]:
> Replying to [comment:13 rbarnes]:
> > I'm running GRASS on a headless machine, so it wasn't possible for me
to use a GUI on it.
> Right.
> On headless machines, use
> grass70 /path/to/location/mapset
> and the rc file will be generated.
If you have no existing GRASS DATABASE, yet, on the machine, I would
recommend starting by creating one:
mkdir GRASSDATA
Then, if you have no existing GRASS GIS data, you have to create a
location and mapset first. Locations are defined by their projection
system. Two options exist to define this projection: either you use an
existing georeferenced file, or you use an EPSG code (see grass70 --help
for details).
grass70 -c EPSG:32630 /home/myuser/GRASSDATA/mylocation
will create the location 'mylocation' (using WGS 84 / UTM zone 30N
projection) and the mapset PERMANENT.
If you want to enter the same location, but in a newly created mapset:
grass70 -c /home/myuser/GRASSDATA/mylocation/mymapset
If you want to create a new location (which always needs a PERMANENT
mapset) and immediately enter another newly created mapset, you can
combine these two steps
grass70 -e -c EPSG:32630 /home/mlennert/gg/mylocation
The '-e' flag tells GRASS to just create the new location (with its
PERMANENT mapset), and then exit. The second call then creates and enters
the new mapset mymapset.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2683#comment:16>
