[GRASS-dev] [GRASS GIS] #3043: Change default color table
trac at osgeo.org
Wed Jun 22 09:07:44 PDT 2016
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: blocker | Milestone: 7.2.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.colors, d.rast, rainbow
CPU: Unspecified | Platform: Unspecified
Comment (by vincent):
Replying to [comment:21 wenzeslaus]:
> In `r.colors.matplotlib` I try to do the conversion from the Matploitlib
objects to GRASS color rules. The GRASS rules are linearly interpolated in
between (when used) which is what happens in the Matplotlib objects I
think.
Sorry I did not read entirely your manual page, the way you proceed (a
proportional mode rule file) is definitely better than what I tried to do
(translating the viscm color ramp to 255 RGB values).
> As far as I understand, that's unrelated to the above. This is RGB
triplet format issue (`0-1 -> 0-255`). I hope I'm doing it right in
`r.colors.matplotlib`:
Anyhow, isn't it a minor issue ? IIUC it's a matter of approximating via
int() rather than round() or considering 256 steps rather than 255. As a
colorblind I don't feel concerned by a difference of 1/255 of a value !-)
To put it in a nutshell : {{{r.color.matplotlib}}} does the job the way it
should.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3043#comment:22>
