[GRASS-dev] [GRASS GIS] #3043: Change default color table
trac at osgeo.org
Thu Jun 23 03:43:14 PDT 2016
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: blocker | Milestone: 7.2.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.colors, d.rast, rainbow
CPU: Unspecified | Platform: Unspecified
Comment (by vincent):
Replying to [comment:22 vincent]:
> To put it in a nutshell : {{{r.colors.matplotlib}}} does the job the way
it should.
{{{r.colors.matplotlib}}} does not provide exact percent values (did I
miss something?). So starting back from my own {{{grass_ramp.py}}} file, I
extracted the cm_data array, then did the 0-255 > 0-100% interpolation via
Scilab.
For those interested, I give in attachment the cm_data array
(grass_ramp.txt),and the sequence of commands run in Scilab
(viscmtograss.sce). It outputs a file which needs some cosmetics, which I
did it in one go :
{{{scilab-cli -f 2viscmtograss.sce && cat rgbtemp | awk '{FS=" "}''{printf
"%s%s %s:%s:%s\n", NR-1,"%",$1,$2,$3}'>grass_0_100 && rm rgbtemp}}}
Finally I propose to add the new "grass" color rule to the existing list
of default ramps.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3043#comment:23>
