[GRASS-dev] [GRASS GIS] #3084: i.segment: notnullcells defined as long too limited
trac at osgeo.org
Wed Jun 29 01:59:10 PDT 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Imagery | Version: unspecified
Resolution: | Keywords: i.segment variable type
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [ticket:3084 mlennert]:
> In iseg.h, notnullcells is defined as long. On Windows this has a range
of –2147483648 through 2147483647.
> We are working on a region that has over 7 billion pixels and so the
nonnullcells variable overflows, becomes negative and i.segment fails with
"insufficient number of non-null cells".
> Two reflections:
> * Shouldn't this be unsigned ?
> * Maybe a long long would be safer, seeing that pixel numbers don't stop
increasing.
For nonnullcells, long long would be ok. But i.segment is not prepared to
handle raster maps with more than 2147483647 cells, at least the region
IDs would also need to be changed, or handled differently. Variables for
region ID as well as the region ID output is 32 bit signed integer, so
there will be another integer overflow, particularly because in the
beginning each cell gets a unique region ID.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3084#comment:1>
