[GRASS-dev] [GRASS GIS] #3085: Batch import with import raster data tool does not recognize projection information
trac at osgeo.org
Wed Jun 29 11:13:45 PDT 2016
information
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
Importing using the Import raster data (menu: file - import raster data -
common formats import) works as advertised when importing a file. However,
when trying to import a batch of rasters in a directory, the
'reprojection' screen is shown, with the message that 'projection of
following layers do not match with projection of current location
(followed by a list of all layers in that directory).
I have had this issue with layers from various data sets, including last
data from the Africlim
(https://grasswiki.osgeo.org/wiki/Global_datasets#Africlim_maps) data set,
which are latlon (wgs84) layers with identical coordinate system header
(using gdalinfo).
To reproduce this, one can export the raster layers from the NC sample
data set, and then import them all in once using the import raster data
tool.
g.region raster=soils
r.out.gdal input=soils output=/home/paulo/Desktop/test/soils.tif
format=GTiff
r.out.gdal input=landuse output=/home/paulo/Desktop/test/landuse.tif
format=GTiff
r.out.gdal input=geology output=/home/paulo/Desktop/test/geology.tif
format=GTiff
r.out.gdal input=elevation output=/home/paulo/Desktop/test/elevation.tif
format=GTiff
Now, when importing them, the same warning is shown (see screenshot)
I am running grass 7.3dev r68774 (but I have experienced the same with
many previous revisions) on Ubuntu 14.04.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3085>
