[GRASS-dev] [GRASS GIS] #3087: v.db.droptable error
trac at osgeo.org
Thu Jun 30 07:01:31 PDT 2016
Reporter: clerici | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Database | Version: 7.0.4
Resolution: | Keywords: db.droptable
CPU: Unspecified | Platform: MSWindows 8
Changes (by martinl):
* keywords: => db.droptable
* component: Default => Database
* milestone: Website => 7.0.5
Old description:
New description:
db.droptable -f table=roads_copy
Forcing ...
File "C:\Program Files\GRASS GIS
7.0.4/scripts/db.droptable.py", line 99, in <module>
main()
7.0.4/scripts/db.droptable.py", line 77, in main
used = grass.db.db_table_in_vector(table)
7.0.4\etc\python\grass\script\db.py", line 193, in
db_table_in_vector
for f in vector_db(vect, stderr=nuldev).itervalues():
7.0.4\etc\python\grass\script\vector.py", line 43, in
vector_db
**args)
7.0.4\etc\python\grass\script\core.py", line 446, in
read_command
return handle_errors(returncode, stdout, args, kwargs)
7.0.4\etc\python\grass\script\core.py", line 313, in
handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None
['v.db.connect', '--q', '-g', 'map=pippopluto at user1',
'sep=;'] ended with error
Process ended with non-zero return code 1. See errors in the
(error) output.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3087#comment:1>
