[GRASS-dev] [GRASS GIS] #2871: lib/iostream/mm.cpp:Fails to build with GCC 6: declaration of ... has a different exception specifier
trac at osgeo.org
Thu Jun 30 09:12:24 PDT 2016
Reporter: sebastic | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.2.0
Component: Compiling | Version: svn-releasebranch70
Resolution: | Keywords: iostream
CPU: All | Platform: Linux
Comment (by sebastic):
Removing GRASS is not my choice, that's enforced by the Release Team in
Debian. Packages with Release Critical bugs get removed from testing after
a month without a fix for the RC bugs.
If we can disable the problematic functionality, that would be a perfectly
acceptable sort term solution.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2871#comment:14>
