[GRASS-dev] [GRASS GIS] #2943: Absolute path in TGIS connection can make db inaccessible in a (mixed) multi-user environment
GRASS GIS trac at osgeo.org
Tue Mar 1 01:29:56 PST 2016
 Reporter:  sbl          |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:  7.0.4
Component:  Temporal     |    Version:  unspecified
 Keywords:  t.connect    |        CPU:  Unspecified
 Platform:  Unspecified  |
 It seems that the connection to the TGIS sqlite.db is defined for the
 mapset using an absolute paths.
 That makes it inaccessible in cases where mount points change, e.g. in a
 multi-user environment. In my particular case,
 /grassdata/ETRS_33N/precipitation_daily/tgis/sqlite.db (produced from
 within Linux) is (naturally) not readable from Windows where the
 equivalent path would be
 R:\grassdata\ETRS_33N\precipitation_daily\tgis\sqlite.db
 One can work around this issue using t.connect -d when starting to work,
 but this is only possible for "mapset owners".
 Would be nice if environment variables could be used
 ($GISDBASE/$LOCATION_NAME/$MAPSET) and first expand/evaluate at access
 time or relative path to the current mapset...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2943>
