[GRASS-dev] [GRASS GIS] #2917: r.mapcalc neighbour modifier uses wrong row
trac at osgeo.org
Tue Mar 1 05:53:41 PST 2016
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.4
Component: Raster | Version: svn-releasebranch70
Resolution: | Keywords: r.mapcalc
CPU: Unspecified | Platform: Unspecified
Comment (by glynn):
Replying to [comment:6 marisn]:
> If I understood correctly, the issue was triggered by any mapcalc
expression containing two to eight references to same map (MAP[n,x] and
MAP[m,x], ...) where n!=m.
The row cache is contiguous, but limited to 8 rows. So it's used if the
range of offsets (maximum row offset minus the minimum row offset plus
one) is between 2 and 8 inclusive.
So if an expression contained e.g. map[-10] and map[10], the cache
wouldn't be used (because it would need to hold 21 rows, which is more
than the maximum of 8 rows). In that case, each row would be read multiple
times rather than being cached.
Any expression using two or more distinct row offsets for a map (no offset
is equivalent to an offset of zero) "might" trigger it. Scripts which use
fixed offsets typically use small offsets, so the range being less than or
equal to 8 is likely. Scripts which use larger row offsets typically do so
by way of using variable row offsets, so it's likely that the cache will
be used "sometimes".
Ticket URL: <https://trac.osgeo.org/grass/ticket/2917#comment:8>
