[GRASS-dev] [GRASS GIS] #2940: Compiling Grass-7.0.3 under FreeBSD: tplot directory (with log)
trac at osgeo.org
Tue Mar 1 06:08:39 PST 2016
Reporter: pieside | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Default | Version: 7.0.3
Resolution: | Keywords: FreeBSD
CPU: x86-64 | Platform: Other Unix
Comment (by glynn):
Replying to [comment:2 pieside]:
> The problems seems to be an old friend:
/home/pierre/tmp/grass7/grass-7.0.3/dist.x86_64-unknown-
freebsd10.2/lib/libgrass_gis.7.0.3.so: undefined reference to `libiconv'
This usually means that it's including <iconv.h> from libiconv but linking
against the system iconv (which may be part of libc).
One way to solve issues with multiple library versions is to create
"include" and "lib" directories, populate them with symlinks to the
desired versions of the headers and libraries, and use --with-includes=
and --with-libs= to put those directories at the front of the search path.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2940#comment:3>
