[GRASS-dev] [GRASS GIS] #2854: results in winGRASS7 32bit vs 64bit: should they be identical?
trac at osgeo.org
Wed Mar 2 14:55:07 PST 2016
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Raster | Version: svn-releasebranch70
Resolution: | Keywords:
CPU: x86-64 | Platform: MSWindows 7
Comment (by hellik):
Replying to [comment:14 glynn]:
> Replying to [comment:12 mmetz]:
> > The results are thus as precise as requested per GCC compiler options
for the given architecture. The same GCC compiler options can lead to
different results under different architectures.
> There should be some set of options which produce the correct result on
any architecture which uses IEEE-754.
> > Generally, with limited fp precision,
> > (a * b) / c != a * (b / c)
> This shouldn't be relevant. The source code won't change between
architectures, and gcc shouldn't perform such approximations unless
specifically requested via -ffast-math or similar (apparently -Ofast
enables this, but none of the numbered optimisation levels do).
> The main issue which occurs with the default options is excess
precision. The x87 FPU uses 80 bits by default; you need to use e.g.
-ffloat-store or -fexcess-precision=standard to force the result to be
rounded to 64 bits. SSE always rounds to 64 bits.
> > In other words, the results obtained with WinGRASS 32bit and WinGRASS
64bit are both correct, even if they differ from each other. The results
are as precise as possible / as requested.
> The issue is how you test for correctness. You can either build for
deterministic calculation so that exact equality comparisons will work, or
you can use a tolerance. The latter option requires case-by-case analysis
(see point 4 in comment:9).
some tests shows that some examples in manuals (modules and addons) seems
not to work due to this issue in winGRASS 7 64-it.
what what be a usable solution?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2854#comment:15>
