[GRASS-dev] [GRASS GIS] #2941: r.sun: wrong sign in equation of time
trac at osgeo.org
Fri Mar 4 02:21:27 PST 2016
Reporter: tomhuld | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Raster | Version: unspecified
Resolution: | Keywords: r.sun
CPU: Unspecified | Platform: Unspecified
Changes (by neteler):
* keywords: => r.sun
* component: Default => Raster
Comment:
Replying to [ticket:2941 tomhuld]:
> Bug report ticket #2876 by fabriziosossan reported a problem with the
equation of time in r.sun, whereby the calculation of the solar time from
the clock (civil) time is wrong. The problem was fixed with a patch for
GRASS 6,
So far the proposed patch has not been applied. Should it be? From the
discussion in ticket #2876 it is not clear to me.
> but as far as I know there the fix was not applied to GRASS 7.
> I would like to suggest the following patch for r.sun/main.c. Since this
is my first patch for GRASS, apologies if I'm doing it worng.
Ideally please submit the diff as an attachment by (in this case) running
# from main source code directory
svn diff raster/r.sun/ > r_sun.diff
(For now, I have reformatted your comment here by protecting it with curly
braces.)
Should your change be submitted in addition to the patch proposed in
ticket #2876 or exclusively your change?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2941#comment:2>
