[GRASS-dev] db.join script wanted
Markus Neteler
neteler at osgeo.org
Wed Mar 9 04:09:18 PST 2016
On Mar 9, 2016 12:12 PM, "Paulo van Breugel" <p.vanbreugel at gmail.com> wrote:
> Thanks Markus, this looks useful. I'll give it a try when appearing in
g.extension.
It should be there...
> In the meantime, a quick questions: how does this extension differ from
v.db.join?
Once db.join works, v.db.join should call it, and the respective part be
removed from v.db.join.
> With db.join, is it possible to join two tables, including tables that
are not attribute tables of a vector layer?
Yes, exactly. It is not related to maps at all. It fills the gap of
handling table joins.
Just it needs to be reviewed...
Best
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160309/49788030/attachment.html>
