[GRASS-dev] How to sample raster values along a vector line?
Moritz Lennert
mlennert at club.worldonline.be
Fri Mar 11 00:02:42 PST 2016
On 10/03/16 18:56, Markus Neteler wrote:
> Hi devs,
> I somehow don't get how to sample values from a raster map along a
> vector line which is several pixels long.
> In essence, something like this
> #1852: r.profile: accept lines vector map as profile
> https://trac.osgeo.org/grass/ticket/1852
> Issues:
> - I tried v.split but don't know how to extract the nodes from the
> resulting map.
> - I also tried v.to.points but the distance is "random". Try this:
> # NC data
> v.to.points railroads output=railroads_nodes use=node dmax=200
> g.region vector=railroads_nodes
> d.mon wx0
> d.vect railroads_nodes
This is the expected result with use=node. Try without that, and you
should get what you are looking for:
v.to.points railroads output=railroads_nodes dmax=200
Moritz
