[GRASS-dev] OSGeo-SoC 2016 application
Luca Delucchi lucadeluge at gmail.com
Wed Mar 16 08:18:04 PDT 2016
On 16 March 2016 at 04:49, Yang, Bo (yangb2) <yangb2 at mail.uc.edu> wrote:
> Hi Luca,
Hi Bo Yang,
> Thank you for the reply and info. It is great if you could co-mentor this project. I would be more interest in implementing my spatio-temporal fusion algorithm as an open source plug-in. Actually, I already have the preliminary python code for the raster fusion, including modules of spatio-temporal semi-variogram calculating, exponential/Gaussian fitting, spatio-temporal fusion, uncertainty estimation and etc. Currently it runs well for fusing MODIS and Landsat data. But it is just a preliminary program, I think a lot more works need to be done to make it professional and could incorporated into GRASS framework.
Could we see and test the code? I'm interesting to test it with MODIS data...
> I've read the link you sent to me. I think it is a good point to add it to r.series.interp, which I noticed author is Sören Gebbert. Should I ask Sören if he is interested to be a potential mentor? Furthermore, could you advise what should I do now to get start for the programming environmental as well as prepare the proposal?
Yes, I think you should ask Soeren, he knows a lot about this topic.
You have to compile GRASS [0], do you have a Windows or Unix OS?
After this you can start to read more about GRASS programming [1]
> Best,
> Bo Yang
[0] https://grasswiki.osgeo.org/wiki/Compile_and_Install
[1] https://grass.osgeo.org/programming7/
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
