[GRASS-dev] [GRASS GIS] #2964: G7: v.extract does not remove islands
trac at osgeo.org
Wed Mar 16 13:19:06 PDT 2016
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Vector | Version: 7.0.3
Resolution: | Keywords: v.extract,islands
CPU: Unspecified | Platform: All
Comment (by mmetz):
Replying to [ticket:2964 sbl]:
> v.extract in GRASS 7.0.3 (and trunk too I guess) does not remove islands
from areas.
This is correct behaviour of v.extract. In GRASS, an area is composed of
boundaries of the outer ring and boundaries of the enclosed islands, and a
centroid. If you extract a given area with v.extract, you get its
boundaries of the outer ring, boundaries of any enclosed islands, and its
centroid. This is identical to non-topological vectors like shapefiles: a
polygon is defined by its outer ring and any inner rings (islands).
Extracting a single polygon will preserve the inner rings but not the
polygons inside the inner rings.
> # From the Manual
> v.extract input=map_with_islands output=maps_without_islands
cats=1-99999
> # and/or
> v.extract -d in=map_with_islands out=maps_without_islands
The manual is misleading because it does not specify the type to be
extracted (should be area) and because it does not specify the layer to be
extracted (presumably 1). The manual is wrong because the given commands
do not remove islands. They are not supposed to remove islands, or inner
rings in Simple Feature Specification.
Manuals of relbr70 and trunk have been updated in r68070,1.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2964#comment:1>
