[GRASS-dev] r.rgb: syntax error, unexpected $end, expecting VARNAME or NAME or STRING
Vaclav Petras
wenzeslaus at gmail.com
Fri Mar 18 08:07:26 PDT 2016
On Fri, Mar 18, 2016 at 10:10 AM, Markus Neteler <neteler at osgeo.org> wrote:
> ok. But another error occurs (missing error handling if the output
> names were selected to be identica):
> Perhaps there is an elegant solution to catch the (user) error above?
Isn't this an issue for every module? I'm not sure if we have a general
solution (as in the previous case).
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160318/e79e4f2b/attachment.html>
