[GRASS-dev] os.remove
Paulo van Breugel p.vanbreugel at gmail.com
Mon Mar 21 02:12:54 PDT 2016
Hi devs,
In the addon r.forestfrag (python script), I used os.remove() to remove
some temporary files (in lines 230, 258 and 430). However, this fails in
Windows, with an error message like below:
WindowsError: [Error 32] The process cannot access the file because it is being used by another process: 'c:\\users\\uqdshana\\appdata\\local\\temp\\tmpwlv54l'
Removing these lines with os.remove() solves the problem, but than the
user is left with these temporary files. Is there a Window compatible
way to remove them in the script?
Rgds
Paulo
