[GRASS-dev] FW: FW: OSGeo-SoC 2016 application
Luca Delucchi
lucadeluge at gmail.com
Wed Mar 23 01:09:06 PDT 2016
On 23 March 2016 at 05:04, Yang, Bo (yangb2) <yangb2 at mail.uc.edu> wrote:
> Dear Luca,
Dear Bo,
> Last weekend I've tried using my computer checking out the source codes and compiled the GRASS in the windows OS environment [0]. In addition, I've studied both t.rast.gapfill and r.series.interp modules. I think that it would be possible to add an interpolation method because it currently supports only linear interpolation. I think it would be a good idea to add Kriging/cokriging to the interpolation methods since it is a wide used rater interpolation algorithm. Although Kriging/cokriging computational time is significantly longer than the traditional linear method, it completes the gap filling process within a reasonable period with much better fusion results, especially for some heterogeneous region. If you think it is OK, I can prepare the proposal follow this direction (it is due this Friday).
I think you should start the proposal, because there is no so much time
> However, I've got the reply from Soeren (see below). He said he can't mentor the project due to too busy this year. Do you have any other person in mind to recommend as mentor? Or are you available for mentoring this project? Please advise.
> Thank you for being patient and helping me.
I have no enough C skills to be the first mentor, I could be the
co-mentor (for testing, helping you with t.rast.gapfill and adding
tests). Is someone else interested to be mentor?
> Best wishes,
> Bo Yang
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
