[GRASS-dev] r.regression.multi failing
Anna Petrášová kratochanna at gmail.com
Wed Mar 23 07:24:34 PDT 2016
On Wed, Mar 23, 2016 at 10:01 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> On 23 March 2016 at 14:31, Paulo van Breugel <p.vanbreugel at gmail.com> wrote:
>> Hi,
> Hi,
>> I am using r.regression.multi in a python script (using grass.run_command())
>> to compute the variance inflation factor (VIF).  It runs in a loop,
>> regressing variables one by one to all the other variables. It sometimes
>> happen that the function fails with:
>> WARNING: Matrix is unsolvable
>> ERROR: Multiple regression failed
>> This causes my script to stop. However, I would like to capture this warning
>> / error, and continue. Do you know how I can accomplish this?
> did you try with try except ?
Yes, specifically:
from grass.exceptions import CalledModuleError
try:
    gscript.run_command(...)
except CalledModuleError:
>> Paulo
> ciao
> Luca
> www.lucadelu.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
