[GRASS-dev] FW: FW: OSGeo-SoC 2016 application
Yang, Bo (yangb2) yangb2 at mail.uc.edu
Wed Mar 23 22:26:07 PDT 2016
Dear Moritz,
Thank you for the reply, and thanks you and Markus could be the mentor of the i.segment project! There are only two days left for submitting the proposal, take into consideration I think I need to switch to the topic of i.segment project now. For my cokriging fusion topic I think I could do it after this summer in the future work.
I've read the source code and Eric's wiki of GSoC 2012 [0]. I think I will prepare the proposal following the direction of adding new algorithms to segment an image into objects-- more than region-growing algorithm. Moritz, you mentioned segmentation algorithm: mean-shift, split-window and watershed. I think some unsupervised classification algorithms would also be possible such as: dynamic thresholding and markov random field (MRF). If you think it is OK, I will start the preparing the draft of proposal from now on, and I think I could have the first version send back to you by tomorrow (Thursday). If you have any suggestions and comments please let me know.
Thanks again to both you and Luca for your guidance and patient.
Best wishes,
Bo Yang
[0] https://grasswiki.osgeo.org/wiki/GRASS_GSoC_2012_Image_Segmentation
-----Original Message-----
From: Moritz Lennert [mailto:mlennert at club.worldonline.be]
Sent: Wednesday, March 23, 2016 10:12 AM
To: Yang, Bo (yangb2) <yangb2 at mail.uc.edu>
Cc: Luca Delucchi <lucadeluge at gmail.com>; grass-dev at lists.osgeo.org; Markus Metz <markus.metz.giswork at gmail.com>
Subject: Re: [GRASS-dev] FW: FW: OSGeo-SoC 2016 application
Le Wed, 23 Mar 2016 09:09:06 +0100,
Luca Delucchi <lucadeluge at gmail.com> a écrit :
> On 23 March 2016 at 05:04, Yang, Bo (yangb2) <yangb2 at mail.uc.edu>
> wrote:
> > Dear Luca,
> Dear Bo,
> > Last weekend I've tried using my computer checking out the source
> > codes and compiled the GRASS in the windows OS environment [0]. In
> > addition, I've studied both t.rast.gapfill and r.series.interp
> > modules. I think that it would be possible to add an interpolation
> > method because it currently supports only linear interpolation. I
> > think it would be a good idea to add Kriging/cokriging to the
> > interpolation methods since it is a wide used rater interpolation
> > algorithm. Although Kriging/cokriging computational time is
> > significantly longer than the traditional linear method, it
> > completes the gap filling process within a reasonable period with
> > much better fusion results, especially for some heterogeneous
> > region. If you think it is OK, I can prepare the proposal follow
> > this direction (it is due this Friday).
> I think you should start the proposal, because there is no so much
> time
> > However, I've got the reply from Soeren (see below). He said he
> > can't mentor the project due to too busy this year. Do you have any
> > other person in mind to recommend as mentor? Or are you available
> > for  mentoring this project? Please advise. Thank you for being
> > patient and helping me.
> I have no enough C skills to be the first mentor, I could be the
> co-mentor (for testing, helping you with t.rast.gapfill and adding
> tests). Is someone else interested to be mentor?
As mentioned privately, I'm only available, like you, as co-mentor for testing and applied advice, not so much on the coding side.
In light of the absence of mentors, you might want to reconsider the choice of topics. For i.segment, Markus Metz is willing to deal with the C-side and I mentor for the rest.
Moritz
