[GRASS-dev] [GRASS GIS] #2456: read CSV from GDAL data directory
GRASS GIS trac at osgeo.org
Thu Mar 24 06:08:44 PDT 2016
  Reporter:  martinl             |      Owner:  grass-dev@…
      Type:  task                |     Status:  new
  Priority:  blocker             |  Milestone:  7.1.0
 Component:  Projections/Datums  |    Version:  svn-releasebranch70
Resolution:                      |   Keywords:  gdal
       CPU:  Unspecified         |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:6 martinl]:
 > Replying to [comment:3 martinl]:
 > > For record list of affected files:
 > >  * pcs.csv
 > The attached patch attachment:gdal_data.diff forces GRASS to use CSV
 files from GDAL.
 The patch was too complicated. Actually, you do not need to force GRASS to
 use CSV files from GDAL, instead GRASS should not override the default CSV
 file location with `SetCSVFilenameHook()`. Simply disabling calls to this
 function lets GDAL via GRASS use its own CSV files. Done in trunk r68128.
 This does not solve all problems because GRASS uses its own mechanisms for
 SRS names, datum transformations etc which might fail to find any
 parameters.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2456#comment:12>
