[GRASS-dev] [GRASS GIS] #2229: error in projection definition
trac at osgeo.org
Thu Mar 24 11:03:44 PDT 2016
Reporter: vincent | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Projections/Datums | Version: svn-releasebranch70
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Changes (by neteler):
* version: unspecified => svn-releasebranch70
* milestone: 6.4.4 => 7.0.4
Comment:
As per r68131 (trunk) the PROJCS (coordinate system name) is now
maintained properly:
g.proj epsg=3857 datumtrans=-1 -w
PROJCS["WGS 84 / Pseudo-Mercator",
GEOGCS["wgs84",
DATUM["WGS_1984",
SPHEROID["WGS_1984",6378137,298.257223563]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Mercator_2SP"],
PARAMETER["standard_parallel_1",0],
PARAMETER["central_meridian",0],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
Ticket URL: <https://trac.osgeo.org/grass/ticket/2229#comment:7>
