[GRASS-dev] [GRASS GIS] #2854: results in winGRASS7 32bit vs 64bit: should they be identical?
GRASS GIS trac at osgeo.org
Fri Mar 25 12:45:23 PDT 2016
  Reporter:  hellik  |      Owner:  grass-dev@…
      Type:  defect  |     Status:  new
  Priority:  normal  |  Milestone:  7.0.4
 Component:  Raster  |    Version:  svn-releasebranch70
Resolution:          |   Keywords:
       CPU:  x86-64  |   Platform:  MSWindows 7
Comment (by wenzeslaus):
 Replying to [comment:15 hellik]:
 > some tests shows that some examples in manuals (modules and addons)
 seems not to work due to this issue in winGRASS 7 64-it.
 > what what be a usable solution?
 For the actual tests as in testsuite, use
 [https://grass.osgeo.org/grass71/manuals/libpython/gunittest.html#gunittest.case.TestCase.assertRastersNoDifference
 assertRastersNoDifference] with ''precision'' parameter for comparing the
 resulting raster to the reference. Also functions like
 [https://grass.osgeo.org/grass71/manuals/libpython/gunittest.html#gunittest.case.TestCase.assertRasterFitsInfo
 assertRasterFitsInfo] have ''precision'' parameter.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2854#comment:17>
