[GRASS-dev] RandomForest classifier for imagery groups add-on
Vaclav Petras
wenzeslaus at gmail.com
Sat Mar 26 10:21:20 PDT 2016
On Sat, Mar 26, 2016 at 12:40 PM, Steven Pawley <dr.stevenpawley at gmail.com>
wrote:
> I would like to draw your attention to a new GRASS add-on, r.randomforest,
> which uses the scikit-learn and pandas Python packages to classify GRASS
> rasters.
Thanks, this looks good. Please consider adding an image to the
documentation to better promote the module [1] and also an example which
would work with the NC SPM dataset [2]. For the addon to generate
documentation on the server and work well at few other special occasions,
it is advantageous to employ lazy import technique for the non-standard
dependencies, see for example v.class.ml and v.class.mlpy [3].
Vaclav
[1] https://trac.osgeo.org/grass/wiki/Submitting/Docs#Images
[2] https://grass.osgeo.org/download/sample-data/
[3] https://trac.osgeo.org/grass/changeset/66482/
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160326/4d7cc8bd/attachment.html>
