[GRASS-dev] os.remove
Paulo van Breugel
p.vanbreugel at gmail.com
Sat Mar 26 11:56:10 PDT 2016
On Sat, Mar 26, 2016 at 7:21 PM, Glynn Clements <glynn at gclements.plus.com>
wrote:
> Paulo van Breugel wrote:
> > > In the addon r.forestfrag (python script), I used os.remove() to
> > > remove some temporary files (in lines 230, 258 and 430). However, this
> > > fails in Windows, with an error message like below:
> > > WindowsError: [Error 32] The process cannot access the file because it
> > > is being used by another process:
> > > 'c:\\users\\uqdshana\\appdata\\local\\temp\\tmpwlv54l'
> > > Removing these lines with os.remove() solves the problem, but than the
> > > user is left with these temporary files. Is there a Window compatible
> > > way to remove them in the script?
> > Perhaps I should have looked harder first, the underlying problem
> > (described here: https://www.logilab.org/blogentry/17873) seems to be
> > that the file needs to be closed at OS level, which can be done using
> > os.close().
> Ideally, files should be handled using context managers and "with".
> Python's own file objects are already context managers, so you can use
> e.g.
> with open(filename) as f:
> data = f.read()
> # by this point, f has already been closed
> For dealing with OS-level descriptors, you can use contextlib (Python
> 2.5+) to easily create context managers, e.g.
> import os
> import tempfile
> from contextlib import contextmanager
> @contextmanager
> def temp():
> fd, filename = tempfile.mkstemp()
> try:
> yield (fd, filename)
> finally:
> os.close(fd)
> os.remove(filename)
> if __name__ == '__main__': ...
> with temp() as (fd, filename):
> whatever()
> # fd has been closed and the file removed
> Use of "with" ensures that clean-up happens in the event of an
> exception or other forms of early exit (e.g. return, break, continue).
Thanks Glynn.. very helpful (but I have to admit that I will need to study
this more carefully to get to understand it all).
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160326/20d8dfb9/attachment.html>
