[GRASS-dev] Rendering from command line does not respect size
Vaclav Petras wenzeslaus at gmail.com
Mon Mar 28 12:12:21 PDT 2016
On Mon, Mar 28, 2016 at 2:53 PM, Martin Landa <landa.martin at gmail.com>
wrote:
> 2015-05-04 2:47 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> > d.mon png width=1500 height=1350
> > d.rast elevation
> > ERROR: PNG: input file has incorrect dimensions: expected: 1500x1350 got:
> >        640x480
> I cannot reproduce this behavior:
> d.mon png w=1000 h=500 out=/tmp/png.png
> d.rast dmt --v
> png: image size 1000x500
Works with output.
> d.mon png width=1500 height=1350 output=/tmp/png.png
> d.rast elevation --v
Using display driver <png>...
png: truecolor status enabled
png: collecting to file '/tmp/png.png'
png: image size 1500x1350
But using the default file name it fails:
png: collecting to file '/.../map.png'
       640x480
When I use file command:
> ls
[nothing]
map.png: PNG image data, 640 x 480, 8-bit/color RGBA, non-interlaced
> Probably map.png has been created by cairo driver? Ma
No sure how this works but I'm not starting cairo at the same time.
Thanks for getting back to this,
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160328/619323f5/attachment.html>
